Well i want to upgrade to the Powermatic 3520b and all set to put the order in But.
The machine weigt is bit over 600 lbs. assembled and once off the truck it has to make it down 4 concret steps and make a 90 deg. turn and thru a opening 30" wide go another 25 ft. then up 1 step and then 16 ft. more to its place of use.
this cannot be done assembled, so i was thinking about removing the headstock, tailstock, banjo and the legs to move it.
So my question is: Would this be a good idea since the lathe was factory assembled and setup and has anyone had any experience with this lathe or the next model up and anyone have this problem and how did you handle it.
Thankyou Roy knapp
Thankyou Roy knapp
