- Joined
- Dec 22, 2006
- Messages
- 7,129
- Likes
- 9,950
Questions about seasoning of rough turned bowls....
As I understand it, water is eliminated from rough turnings at a greater rate from the end grain. So, (theoretically speaking) I should be able to end my practice of storing rough bowls with spacers between each.....in other words, just stack one inside the other. My usual habit is to turn bowls using a waste block, so one side of the bottom does not eliminate water because of that. The only exposed surface is the bottom/interior of the bowl, which when stacked will have another bowl resting on it. See what I'm getting at?
Since my recent purchase of a 35# postal scale, I've been weighing weekly, and it would be much more convenient to just stack the bowls.
I'm still using the moisture meter to get an initial %h20 content from the bowl blank.
How often do you weigh?
Is the fact that I use waste blocks going to be problematic for me, if I season them stacked one on top of, or inside of the other?
I've been seeing a bowl or two with %h2o content over 10% that seem to be stable with successive weighings, but I'd rather see them 6-8% before I finish turn. The fact that it's cold in my garage may have effect on some of these bowls. I usually maintain a temperature of about 40 degrees F out there.
How does the season of the year effect your seasoning practices?
The pic shows bowls using spacers between each. If I can get good results by not using the spacers, I'd save on shelf space, as well.
