I have been using my bandsaw (Grizzly 17" 2HP, timberwolf 1203AS 1/2" blade) to rip some walnut logs, less than 12" diameter, into spindle blanks. In the middle third of some rip cuts I will hit a "tough" spot where it is almost impossible to push the log any further. When I can get it to move forward after about a 1/2" the cut will go back to normal cutting. This does not always happen, even in the same log. I have inspected the "tough" area and have not found any indication of nails, rocks or any foreign object. What would cause this?
