What do you recommend as a chain type for efficiently processing blanks with my new (to me) 572XP saw? Crosscutting and ripping, mostly local hardwoods, 20" bar.
I use Stihl, not Husky, so it may be different with them, but when I was trying to learn about saw chains, I was using a guide from Stihl USA which talked about a particular chain. I'm in Canada, and things weren't adding up, so I contacted Stihl and a rep explained to me that THAT chain was a low-kickback chain (also called safety chain). Standard on new US saws, but not even sold in Canada. So you may run into those chains; your call whether you want to use them or not.What do you recommend as a chain type for efficiently processing blanks with my new (to me) 572XP saw? Crosscutting and ripping, mostly local hardwoods, 20" bar.
I replaced my ageing 272XP with the 572XP a couple of years ago. I would consider replacing your 20" bar with a 24" as it makes the saw better balanced. It will handle longer bars but I think the 24 is the sweet spot. Depending on how your processing the blanks the longer bar may keep you from bending over as much.any chain will do the job. most important is keeping the chain sharp and avoiding cutting into dirty logs or getting it into dirt.
Any chain is good as long as it's not a "safety chain". The safety part is an odd raker that is very high and limits the size of the chip to an unacceptable fine chip and is very slow cutting. Now your question about ripping. A ripping chain has a very low angle on the tooth, almost zero degrees. I never rip from the end grain with a crosscut chain because it's way too slow. I cut the log to the length of the bar so I can rip from the side, long grain. You have to watch your speed so the curls don't jamb up in the guard by the motor. On my 20" I cut off some of the guard behind the sprocket to get better curl ejection.
Like all metal and woodworking, tooth count is influenced by how thick the stock is. Ideal cutting involves the proper number of teeth in the material at the same time. Skip tooth is not good for smaller diameter logs, and is a necessity is huge logs.I went in to a chainsaw store to buy a saw rather than the big box store. They asked me what I was going to do with it and I told them I was a bowl turner and cutting up blanks. They suggested a skip tooth chain since most of what I was going to be doing with it was ripping. The skip tooth still cross cuts fine.
I keep 3 or 4 chains and swap them out. When I'm on the last one, the other 2 go to the saw shop for sharpening. I probably use up chain faster than hand sharpening, but the convenience and consistency is worth it to me.
I found that I could pay for an electric chainsaw bench grinder pretty quickly compared to taking them to a sharpening shop. Especially if that shop sells chains. I never did measure the amount they remove for each grinding, but my chains lasted a lot longer when I did the grinding. They had an incentive to be a bit more aggressive!
@John K Jordan. I’ve never gotten the hang of chain sharpening and have messed a number of them up before finally deciding to just send them out. Curious what type of electric sharpener you might recommend.
Yep, Bailey's and Madsen's are my go-to sources for saw related stuff.
And PPE is worth it. I've nicked my chaps and steel toes a few times over the years but thankfully nothing serious. I have personally witnessed chaps absolutely save the lives of friends on two separate occasions.
And yes - you can search here for arborists near you:
For the record, I'm jealous of your equipment...
Yes, Madsen's sells to anyone, but they are a small old-school shop, so you need to call and talk to a human.Can anyone buy from Madsen's? Looks like they cater to those who work for a living!
I've bought and used two, didn't like them for several reasons. It's a problem getting them sharpened in some places if they haven't bought the diamond wheels. I sharpened them myself with a cylindrical diamond bit in a dremel.Is a carbide tooth chain worth the extra expense?
Reason for asking is I was cutting bowl blanks and chain meet a nail and nail won and I need a new chain.
