What’s on your carving/embellishing bench?
Love the “ What’s on your lathe ?” thread. Just seeing if anyone interested in a carving / embellishing thread. I’ll start.
I'm just starting to carve/embellish. I
My first attempt, sitting on the bench now
I really haven't done much carving or texturing, but I'm trying to push myself. I turned this piece of white oak from a friend at the local mill. I didn't notice until I well into turning it, that it wasn't a solid piece, but a glue-up of a couple boards. It seemed more noticeable on the rim, so I decided to add some paint and texture. I worked some liming wax into the open grain and put a black base coat on the textured area. I'm considering a layer of copper paint with the aging activator stuff on top, then maybe a light drybrush of plain copper or light wipe of copper gilding paste on the tops of the texture.
Here's what it looks like this morning. I painted on the copper, let it dry, then applied the activator. I had to hit some spots I missed, then wiped gently with a damp towel. All bright copper was too harsh, but all aged was really too much as well. It seemed to remove some of the excess oxidation and bring back a bit of the bright copper for nicer balance.PXL_20260206_130347633.MP.jpg
I personally use a Ram BP-HST. It’s a pricing unit that I just upgraded to recently. I was using the Ram BP-50 which was a great unit. I wanted something that would turn the 1/4” bits for heavier carving. Not a fan of the foredom type units. They’re great for hogging heavy material but I experience hand fatigue fairly quickly. I can use the BP line of tools all day with almost no fatigue . As for used check with your and other local clubs. I sold my old unit to a club member. I but most of my bits from MDI and some from Bits For Carvingwhich is J Paul fennel. Hope this helps
What hand piece did you get? Looking at the page right now,
BP-HST Set with Truflex Handpiece and Pedal
Have a nice foredom but am looking to get a micro motor as well for delicate stuff
This recently came off my carving bench. Winter Twilight, one of my New England Series pieces.
Way cool! Very nice, you arent kidding with your statement about the carving rabbit hole, dangerous for a tool addict like myself. Im wanting to try carving stuff like your piece and Teds, can bring interest to some more plain wood turnings, wondering about carving green?
Just a dentist set up
Hugh, if you were using a dentist drill set up, and the bits were flying out of the handpiece, the problem might have been the turbine. That is the nose cone on the NSK, and the collet on the angled handpiece. These tools are delicate and can be damaged when trying to force the bit through wood or simply being 'hamfisted'. For anyone using these tools, if your bit no longer stays in the nose cone or collet, the first thing to look at is replacing that part. On the NSK, it's a $200 part to replace.
I have a couple more but they don't really show much.
I used rotary tools to cut the curve on the inside of the foot. Then rasps and sandpaper to get blended in. I know I'm getting there when it takes the edge of the tape away and as long as I'm going lightly the tape protects the rest of the bottom.
After removing the tape I finish sanding, then wipe it with mineral spirits to find sanding scratches I missed.
There is always a chance four legs don't sit flat and need adjusting. This one was fine.
Really nice piece, i like the idea of doing the legs, gives a different oomph to the design, just seems to match better
hugh, if you were using a dentist drill set up, and the bits were flying out of the handpiece, the problem might have been the turbine. That is the nose cone on the NSK, and the collet on the angled handpiece. These tools are delicate and can be damaged when trying to force the bit through wood or simply being 'hamfisted'. For anyone using these tools, if your bit no longer stays in the nose cone or collet, the first thing to look at is replacing that part. On the NSK, it's a $200 part to replace.
I on sold it
Finally finished it up.
Maybe something like this grex sander?
Or this?
And use 1”.super soft backing pads for the tight stuff?
Can always make custom pads too,
Another idea is the King Arthurs tools round nose sanding drums, think they have a narrow one, i have a set of them that i got with a sander
Hey, does anyone else inlay grooves in wood with copper, aluminum, or brass powder? The first time I saw this method the grooves were cut freehand
I don't have good pictures, just this: cut a groove in the wood, add very fine brass powder and CA glue or epoxy. Sometimes a bit tricky if working around a circumference. Polishes nicely, can look good (better than this!) Can add a nice touch.
I made and sent these to a friend in Italy about 10 years ago. (looking at it now, I see the brass feet I turned for the Cocobolo box are too big! Oops. But she didn't complain.)
These were part of a birthday gift box of goodies. She shared with friends and family.
I have inlaid twisted copper wire into bowl rims before - just take some old 12-3 or 14-3 Romex and strip the outer sheath , fold the bare ground wire in half and catch ends in a vise, chuck up the other end in VSR drill and at low speed just twist the wire up nice and tight , then cut what length you need to inlay and cut groove for it - glueing it in can be as simple as epoxy or CA glue to fill the gaps, then turn as usual?
Don't have pictures but both bowls sold very quickly when I put them out...
I have inlaid twisted copper wire into bowl rims before - just take some old 12-3 or 14-3 Romex and...
I did that a time or two. I'd drill two holes a little into the wood, one for the start of the wire and one for the end. Last time it was a tool handle after shaping the wood - wrapped with bare copper wire it actually felt pretty good.
On the topic of Image transfer from my laser printer to acrylic gesso on wood.
I am learning how to use gesso on my plates and other turnings because it seems to simplify using watercolor pencil. Trying to use acetone transfer results in a mod podge. The acrylic melts and "eats" the paper. However I discovered that a xylene pen like the Chartpak AD Colorless blender pen works pretty well.
I have had good success with refilling these pens when they go dry by leaving the tip of the pen soaking in xylene that I buy by the quart at the local hardware store.
Caution: These pens are colorless but FAR from odorless. Read the label and only use them with a lot of ventilation.
Does anybody else use this? I'd be curious if there is something friendlier than xylene I could use.
