What’s on your carving/embellishing bench?
I have had a small walnut bowl on my Trent Bosch carving stand for a few days. It's sanded and has a few coats of finish on it, except for about a 1" wide, slightly raised band to carve, burn, and/or texture. I dug out my micromotor and practiced on a scrap (broken piece) but it seemed too slow. Then I fired up my burner pen and tried a few different tips and patterns, but didn't like that either. So, there it sits, staring at me every time I walk into the shop. 😒
Don’t give up! Post a pic , one of us may can provide an idea for that area.
How about stippling? I use a it a lot, mostly with spindles and small things but sometimes with bowls. I use a small sort-of egg shaped carbide bit in dremel, touch the end to the wood to make one small dished spot, then another, then another… overlapping, randomizing, until the area is filled. Can take a bit of time. Then go over it lightly with 600 grit sandpaper and apply finish.
This is an example, Bradford Pear, carved then stippled. (After I finished it I decided I wasn’t wild about the proportions but hey, it’s done.)
This spindle has the same type of stippling.
I have four or five hollow forms sitting on a rack in the shop and trying to figure out what I want to carve or burn on them. Look at them every time I’m in the shop. I think I have it figured out and then change my mind😁
Here is the big brother of the Elm burl I posted earlier. I am putting 4 feet on this one mostly to distribute the weight because it is about 14" in diameter. This is a once turned bowl that was sanded to 320 green and let warp and wrinkle. I do put a bit of a curve on the tenon before removing it from the lathe. The rough carving was done with a Merlin 2 and a rough disk. I put the painters tape on to protect it from hand work with rasps and sanding.
View attachment 80300View attachment 80301
Thanks for the process pics. Would love to see more if you took them.
I have a couple more but they don't really show much.
I used rotary tools to cut the curve on the inside of the foot. Then rasps and sandpaper to get blended in. I know I'm getting there when it takes the edge of the tape away and as long as I'm going lightly the tape protects the rest of the bottom.
After removing the tape I finish sanding, then wipe it with mineral spirits to find sanding scratches I missed.
There is always a chance four legs don't sit flat and need adjusting. This one was fine.
Very helpful thank you!
My only fear is spending a bunch of money before trying it, only to realize I’m not good at it.
Maybe visit someone with the tools and experiment, or start with something very cheap and move up if inspired. I carved for years with Dremel tools - their flex shaft helps prevent the feeling you're holding a sweet potato. I also did a lot of carving with hand tools and files over the years but not on woodturnings..
Later, some more professional motorized options presented themselves, used but in good condition (and with lots of extra bits and such.
No, I was but the club doesn’t exist anymore.
I know i have two additional clubs within an hour drive of me. One I just use their zoom meetings. Maybe contact clubs not so close. Many have mentors. That way you may use their micro motor to gauge what you need before you by. Good luck.
