What’s on your carving/embellishing bench?
On the topic of Image transfer from my laser printer to acrylic gesso on wood.
I am learning how to use gesso on my plates and other turnings because it seems to simplify using watercolor pencil. Trying to use acetone transfer results in a mod podge. The acrylic melts and "eats" the paper. However I discovered that a xylene pen like the Chartpak AD Colorless blender pen works pretty well.
I have had good success with refilling these pens when they go dry by leaving the tip of the pen soaking in xylene that I buy by the quart at the local hardware store.
Caution: These pens are colorless but FAR from odorless. Read the label and only use them with a lot of ventilation.
Does anybody else use this? I'd be curious if there is something friendlier than xylene I could use.
From your description, I assume that you have tried and discarded as not helpful the pyrography technique of using heat to transfer the laser printer toner to your surface. If my guesstimation is incorrect, then this technique may be worthy of some investigation / experimentation. Benefit would be no nasty fumes, risk is that you might end up "burning" the surface.
Good luck!
I actually found a soldering iron with a smooth disk at the hot end sold as a "bunny burner". It wasn't very easy to use or very effective last time I tried it. It might not have been hot enough. What sort of pyrographic tip do you use when you used that method?
Well the budget may effect the outcome some. But I have a selection files both engineering and rifler files. I generally buy the low end of the market Chinese files as wood kill files. OK if you want real quality the Swiss make needle files at around $200AUD per set 6-8 or so. Plus I have several Dremel's with a wide variety of burrs. carbide,HSS diamond etc. Ideally high speed is the way to go if you're doing small intricate stuff 100,000+ Oh and patience :), soft wood has different characteristics to hard wood , the idea is to mess around till you find a species you like . My avatar is fairly common to what I do, Solomon Island Queen Ebony or Tubi around 4" square
Hughie, the second picture is very beautiful. How did you carve those curved lines—did you use a bent chisel? I have a book by Liam Flynn, and he made pieces like that using exactly that kind of tool. You have to calculate everything perfectly. I imagine it must be frustrating when the last curve doesn’t line up and you have to squeeze it in so it doesn't stand out too much.
