What Do You Sign Your Projects With?
Red Deer, AB
Hi all, I’ve been turning for about eleven years now. I’m always looking for a way to sign my bowls. I have a rubber stamp and some not so permanent black ink. I see that Mike Mahoney uses a wood burning unit with a scroll tip (or something) for writing his signature on the bottom of his projects. I’m thinking that looks to be the best idea I’ve found so far. I’ve looked at a Colwood WB-Detailer but darned if I could find the correct tip for sighning your signature using cursive writing.
Lee Valley here in Canada has what I’m looking for but the Colwood pieces I would have to purchase totals about $38.00 bucks cheaper.
What do you guys recommend and use?
Thanks in advance.
Chris
I used to use archival ink pens (india ink pens) I'd buy on amazon - However I have since transitioned to a LaserPecker LP-1 engraver (I posted photo of how I set mine up in banjo in another thread somewhere) There's a few others here that use LP as well. I at first did not care for the "factory made" look of brands, stamps and laser engravers, but then my penmanship which was always not all that good (just a notch above the proverbial doctor's signature) has degraded (age related) so I went with the Laserpecker since I already had one that I'd been using for some flatwork designs.
Did you do a search here? This subject comes up all the time.
I used to use a dental handpiece and burr. My handwriting sucks, so I'd print a full page of different sizes and fonts. I'd cut some out, pick an appropriate size and decide on placement. Then I'd use a temporary 2-sided tape to hold it in place. I printed them with red ink, so where I had been and where I still needed to go, were different colors. When followed it and peeled off the tape and paper, it usually revealed pretty good results. It was time consuming and being out of printed signatures or tape could bring it to a halt.
I ended up buying an early pod version of the Laserpecker (LP1 Pro?) and I've really been pleased with its versatility and capabilities. It would be cool if it were more powerful and could cut stuff, but it does burn in pretty nice. On one very dark walnut piece, I let it repeat 2 or 3 times, then used a lacquer pen to fill/highlight the logo. I've also burned patterns, poetry, artwork, company logos, etc. Once set up, I can do a batch of pieces while I do other stuff. It gives me a beep when it's done, then it's less than a minute to start it on the next piece.
This is an archival ink pen. Very fine tip, .2mm I think it shows on the pen, and they get wider and also other colors. Available at arts and crafts stores near you and/or your amazon account. I do my writing with it on bare wood, give it a couple minutes to make sure it's dry, then go over it with oil finishes.
Well, I don't have the time for a laser engraver, and all pieces are different sizes. Same with a woodburner. I go to a local art supply and buy some "archival" pens, Mine are Faber/Castel, and black. Since I don't turn black walnut, not a problem. The walnut oil finish I use does not make it smear around like the sharpies do. I think sharpie does have a pen that won't smear, but some times they seem to, and some times they don't....
For the most part I use my dremel with a very fine burr that i have ground myself. Then go over with a very fine Sharpie
This is the wood burner I use. Overall, it works pretty well, though I often have to go over areas of the signature multiple times to make it equally dark and on open-grained woods it leaves burn blotches if I go too slow or linger in one area too long. But I’m getting more accustomed to it and I think the signatures are turning out better and better but it’s definitely not as easy as just writing with a pen.
Here’s a 15” cottonwood bowl recently signed for an example.
Tom
I'm also a Pigma Micron archival pen fan and I know others who use them. I've only used the black.
Also, if you use the forum search you will find lots of past discussion on signing turnings.
Perhaps an interesting story. When in a class taught by the late great John Jordan and Clay Foster (hollow forms, color, embellishment, metals, more), someone had the idea of a class project to make a small bowl as a gift for the craft center director. Here are Clay and JJ at the lathe and JJ using his double-ended scraper.
When the bowl was done, John lamented he didn't bring a pen to write on the wood.
I pulled out a set of Pigma Micron pens; he said that was exactly what he wanted!
(I didn't think to get a picture of the signed bottom of the finished bowl.)
I've never had a problem, under finish or on top. Doesn't work well for dark wood. I see I've bought these sets 3 times, some for gifts.
The Pigma have been working very well for me. I used to just use a black ball point pen under the finish, but even hidden from UV exposure, that ink fades away dramatically over many, many years. Some 20yo signatures look about 75% faded away.
Thanks in advance.
Chris
I have a small laser cutter/engraver, I designed a logo and it's nice. Gives me the freedom to change my mind on log and/or customize engravings. That being said, it's a little cumbersome; takes a bit of practice to get right. I always do a trial on scrap before committing to the piece. I'f thought of a branding iron too. It's a hard decision, to be sure.
Gusto. I sign them with gusto.
But seriously, I have a Colwood detailer with a ball tip and a micro-point depending on the size of the piece. For my painted pieces, I use a paint pen of a contrasting color. Sometimes black, sometimes gold. Just depends on the piece. I also notoriously forget to sign before I apply finish, so that complicates things.
I use archival pens, and I sign them 'Richard Raffan'. If anyone knows a turner who gets higher dollars than Raffan, I am willing to change.
Ha!
I just sign mine "John Jordan". (I lie, I use John K Jordan or JKJ if not enough space.)
I've mentioned this before - when I started woodturning I didn't know about the other John Jordan - a friend told me just to sign with my name and people will send me a lot of money! (I have had some packages and tools sent to me by mistake and vice-versa. No one sent money. Miss that guy.
It'll come as a shock to you, but I've always been very competitive when it comes to pricing my bowls, mostly because my name means nothinig to most people who've purchased my work. They tend to buy them because they feel better in the hand than other bowls.
Love it! I don't sell but I sign and date a few things, for example the name and date on a housewarming or wedding present seems significant. Or something donated to a benefit auction. Or just to help me remember when I made something and what kind of wood it is.
And although author's autographs have value to me for the memories, not one person has offered a wooden nickel for either of these books! (Of course, I keep extra copies of books that have helped me the most to give/loan to students/friends who show promise but could use more encouragement at home. And have indicated they are able and willing to read... seems to be getting rarer :()
BTW, I've taken to heart the advice to ignore the pain and occasionally cut a turning in half to find out what made THAT piece feel better or worse in my hand. Other turners are horrified.
I've done that with non bowls too, in this case mostly to teach how and why I shape the walls on certain things.
I just saw this, and please accept my apologies if it came across as anything other than a joke. I shouldn't have brought price into it; I was just thinking about impersonating a famous woodturner, and yours was the first name that came to mind.
Thank you for all the books and videos; I've learned a lot from you.
