What's the next toy.. errr tool?
I just got Lyle Jamieson’s hollowing rig. This thing is rock solid. Easy to set up and hollow. I just had a hip replaced, I was able to just pull up my stool and sit and hollow with one hand. Going to have a lot of fun with this!
Looks good, how long of a lathe is that with the extension?
Wonder if there's a good friday sale coming up?
Guessing I’ve done 100+ hf’s with my Jamieson system in the ~6 yrs I’ve had it. At the time it was the best value for the $ for the size range it will handle when all the various bar sizes and bends are added up, and likely still is. I did replace the laser with a diy camera system that I much prefer. It does require more storage space vs articulating - mine hangs from the ceiling, bars in a drawer.
If turning wet wood, and starting hollowing, spritz the OD with water and wrap with stretch plastic wrap (I use the 6” packaging stuff from walmart). Keeps it from drying and warping.
It’s a Powermatic 2014 so I have a 20” bed. The extension is 13”. I can bring it up level to the bed to give me 33”
Don’t know about the Good Friday’s sale but good luck!
Yes it does take up a little space, I’ve got it hanging on the wall out of the way. Good idea with the water and wrap. I just ordered a roll of the six inch. Thanks Doug!
My next (big) purchase will be a Bosch visualizer.
But what I really want doesn’t exist—a scrub tech. As an ex-surgeon, they were vital. They stand next to the surgeon with a tray full of commonly used tools and a back table with less commonly used and larger tools. You call out what you want, hold your hand out, and a couple seconds later—sometimes instantaneously with the great techs—it’s in your hand and you keep working. And when the case is done, they clean up!
Wife won't do it?
As an ex- surgeon $ is likely not an issue, a camera system is pretty easy to diy for a lot less $. Easy to turn/make a camera adapter for a laser bar for a hollowing system, and an old computer monitor can be used. Can adapt a “hole in desk” monitor arm mount to mount to the lathe. As a retired engineer I enjoy making my own “stuff” and saving lots of $’s, decades of value engineering and fab work is just engrained in me.
Yup, all would be good, but the cleanup would be great.
Scrub tech: I'd pay in wood and tools and peacocks and dollars for someone to keep my shop clean. It's such a mess I've had no takers.
Wouldn’t it be nice to have a down draft floor with a grate large enough to suck the shavings and dust out. Might not work well for green ribbons but dry wood chips would disappear.
There's an easy solution. Turn smaller things and make smaller shavings.
Also, I keep a big plastic tub under the lathe which catches most of the shavings (and anything else I drop). Periodically haul it outside and dump the shavings in the woods.
When I gave this lathe to a friend he said "Can I have the tub too?!" Sho 'nuf.
I'd hate to have a down draft grate in the floor. What about the $100 bills I drop?
Folks here are way ahead of me.
I did pick up this used Dewalt DW735 today.
Saw it advertised locally on FB market place with the table for $400.00
It belonged to a nice older gentlemen who's a finish carpenter and is retiring to take care of his wife.
He had two storage units packed full of tools, they all looked like new as does the planer.
I didn't even bother to dicker, just handed him dead presidents.
I don't know why the photos post sideways.
That’s a heck of a deal with the table included. Had the 735 for ~12 yrs, probably the best “table top” planer available. You can make a jig that holds the planer blades for resharpening, using sandpaper on a flat surface. Good for small nicks, not big gouges in the edge. Can post pics if interested. Tried to find my original source to no avail.
Also, Tormek sells a jig to sharpen planer and jointer blades. I haven't used it yet since my planer came with spare blades.
I never sharpened jointer blades either since the jointer (8" PM) is still in the original unopened crates. Maybe I should sell the thing since my flat wood intentions dissipated as the woodturning took over. I have a very old 6" jointer in storage anyone nearby can have - it needs to find a home before I cut it up for scrap.
I’ve tried that jig, doesn’t work too well for the type of blades in the 735 and some other bench top types. The blades have a fixed position from center, locating holes in the blades. This is to make switching out for new blades very easy.
All edges have to have the same amount of material removed to remain equal distance from center. The manual method is much easier to control vs using a tormek, count the # of strokes and rotate blades through the jig (it holds 2 at a time. Also why only dull blades with small nicks are really sharpenable. Big gouges make getting the height accurate a pita.
Actually thats a good idea for a smock, a welding jacket,,,
Lot lighter than my BDU combat shirt, keeps stuff out and off but is kinda warm sometimes.
You being in HI my "smock" would fit right in. I'm a super size kind of guy and a place where I get my t-shirts had some bigger even for me Hawaiian shirts on clearance for very little money. I wear them backwards so the pocket doesn't fill up and the collar works really good backwards.
Continuing with the toys....... I've added a Trent bosch stabilizer and tools. Originally got the laser but just last week I put together a camera system for it.
I've added a right angle platform and some Carter and son tools (spear point scraper, couple of roughing gouges)
But I still need more chucks! lol
I went through all that, too. I settled on the Laserpecker 1 for $300. So far it works great. I don't like my handwriting and have had mostly poor results with an India ink pen. The brand didn't work at all. Too many uneven surfaces. I agree with Lou that the signature looks more commercial but I can live with that.
View attachment 57688View attachment 57689
Here are a couple of test pieces. You can see the failed brand stamp. I could use a different font for the year and species to make it look less commercial.
Yea, the brands just dont work
Yep - they ARE, (hit and miss) you do get what you pay for (and even then sometimes not even that if the brand has a great marketing campaign) as I have found. I got a "100mm" x-y type engraver ($189) because it was cheap, It works quite well, but extremely fiddly, and only really works on Flatwork, and if you need to do an image bigger than 80mm x 80mm , you have to get lucky with getting things correctly patched together in individual engraving sessions - It rarely hits EXACTLY where you had it lined up "last time" ... I got a LP-1 , cheapest model, and while it is more portable (Could mount it in tailstock and engrave bowls) the engraving depth and darkness is hit and miss, even with identical settings in identical woods one after the other. It is also very sensitive to any and I do mean ANY movement while it is working (even a hiccup if you are close to it) So after spending almost $400 on 2 different laser engravers, neither of which I would want to rely on for customer work (unless I have plenty of spare identical pieces if one doesn't make it) so now I am seeing the logic of saving up and spending the big bucks on a quality machine with a company that can back up their product (and not just half-a$$ed chinese-to-pidgin-English translations) I suppose same goes for any other tool you buy these days , but once you find a quality brand you would stand up and swear by (as if your pocketbook depended on it long term) It'd be worth its weight in gold.
Good input,
Curious what would be a solid brand of laser printer for this kinda stuff, my turning is evolving but am primarily a woodworker so always have something off the bench, is time i mark this stuff.
Mahalo
Tom
Stuart has restarted tool production and is making the Batty rests. I think the 5” platform is the largest though. He was setup at SWAT this year with a display of all the tools he has reintroduced.
Randy
The Batty tool rests are an incredible addition to the sharpening operations in my setup. Highly recommended.
Under the homemade tool today-----
put a handle on my eBay knurler.
I think my next big tool is going to be a combo lathe/mill from grizzly
Been looking at this thing for years, think it would be excellent for making parts and tools and specialty stuff thats just too expensive to get made especially if its experimental.
Would love to get its big brother gunsmithing lathe but is just too expensive and really dont need it.
Hell my shop is crowded as it is!
I don't know anything about that machine, but can promise a mill and metal lathe will get good use! I bought a separate lathe and mill from Little Machine Shop and it's let me make or fix so many things. (I've probably made more things for friends than myself!) But don't forget about the tooling which can be endless - carbide bits, end mills. Maybe they have a tooling package deal like LMS offers. For measuring, I could get by with calipers, a dial indicator and a dial test indicator, and a couple of sizes of micrometers. A height gauge is icing on the cake but really needs at least a small surface plate - I think mine is 9x12x2" granite.
And I probably use all this as much for wood and plastic (HDPE, etc) as I do for aluminum, brass, and steel.
I put mine along a wall in the back room of my shop. The lathe came with it's own stand with a catch pan and for the mill I built a strong table-top to go on a repurposed kitchen cabinet. Put some wall cabinets above. The storage space is useful.
A good way to cut up steel is handy - hacksaw and thin abrasive cutoff wheels will work but a metal-cutting bandsaw can be invaluable. I found a big jet horizontal band saw but much of the time I reach for a Milwaukee Portaband. I found a local metal fab shop that would let me pick through their bins and racks of offcuts and give good prices on mild steel. And we are fortunate to have a local recycling yard that sorts things out and sells to anyone.
I wrote about this before: I think the most comfortable way to use a big bench vise is on a frame about knee-height from the floor. The horizontal extensions at the bottom keep it stable.
