Why wouldn't this work for setting tool rest height?
USA
Seems like it would help? Put it on your round stock or tenon and double check tool rest height and where the tool is cutting when rested on the tool rest.
Because it’s not that important, and often the rest needs to be other than on-center.
A metal lathe is a different story for different reasoning.
Tim
I was thinking more along line of setting the tool on top of the tool rest and making sure it's cutting on line or slightly above.
edit: I didn’t even notice that was for a metal lathe. I think I need more sleep.
Hmmm....
I've never thought about this much - I just adjust the rest to what "feels right" for the situation. I'll try to pay more attention when I get some lathe time.
I adjust the tool rest height based on the tool and how I hold it, the grind, the distance from the wood, and what gives me the cut I want for a particular turning. I learned long ago that raising or lowering the tool rest up or down by even a tiny bit can make a difference. And the best rest height might be different for a person of different height or arm/body proportions.
I might use a different height when turning long, thin spindles vs larger diameters. If the rest height isn't just right I'm afraid I might compensate with my shoulders or arms which could add tension and fatigue after a while.
BTW, I don't know how others make fine adjustments on the tool rest but what works for me is to hold the post between left thumb and forefinger resting on the top of the banjo, loosen the locking lever, then adjust the height - this way I can feel just how much I'm moving it.
Hard to explain, but for me the rest height is one key to being "in the zone" for spindles.
When you use a scraper, the burr is doing the job, not the flat of the steel. I was taught to keep the handle higher than the burr to prevent the scraper from self feeding and getting a catch.
Completely unnecessary. With time and practice, and honestly, verbally repeating to yourself the laws of cutting tool presentation before you present the tool to the wood, micro-adjustments of the tool rest and the constant fluid movement of the tool on that rest to achieve your cut will become so second nature that you could do them in your sleep.
Just please keep your fingers out of the smashing path of the loose tool rest in case you touch the loose rest to the wood while the wood is spinning. Such adjustment is commonplace among seasoned turners (watch utoob for examples), but it is a dangerous habit. Adjust the rest only when the wood is not spinning.
Are you serious? My scrapers cut without a burr. They cut at the joint of two flats and cutting occurs when the sharp end touches the wood in the right position like Steve says above. Wood is different than steel. In over 30 years of machining steel I never had to worry about tool presentation. The only worry was an interrupted cut that was mostly taken care of by grinding off the chip breaker on the carbide insert that usually made it across the 50 plus 1 1/4" holes. For over 90% of my time at GE I turned parts for the motorized wheels, you know those wheels that took those 15 foot tires for deep truck mines.
I have a homemade jig that looks a bit different but does essentially the same thing. I set all my tool rests to 1/2" below center and a punched mark to indicate that specific height using a modified hose clamp. This is the best height for using scrapers that are 1/2" thick, and gouges that are 3/8" to 5/8" tool diameter. For tools that are outside of that perimeter, it's an easy adjustment to lower or raise the hose clamp appropriately. When done, it's easy to bring the hose clamp back to the punch mark......I never need the jig again!
Some here think it isn't necessary to get the tool rest height perfect, but I will disagree with that assumption. I guess it all depends on how refined of a cut you are attempting to produce.....and with that goal in mind, how fine the starting sandpaper grit you can use.
I consider these things to be critically important... :)
=o=
So, forget about tool rest height and imagine you just want a quick way to have the exact centerline of a piece. Still not worth the $7.00 it cost?
Dead serious. I cant believe that you didn’t set up your tool to be somewhat on center cutting steel. You must have never cut threads, or at least eyeballed that the tool was close to center. Never is a very bold statement! I’ve taught way too many classes where someone gets a catch with a scraper. When they get deeper into a bowl, they have no feeling for where center is and a crash results. This usually happens a couple inches up the side. Unless you use a stone to flatten your steel after every time you sharpen, there is a burr there from the grinding process. I am highly aware that wood and steel are different. I worked in a model shop at Caterpillar and turned steel for over a 15 years and have turned wood for over 38 years with personal time turning with John Jordan. I haven’t seen it all, but I’ve seen a hell of a lot over the decades
When I started I worked on a vertical boring mill with a 15 foot table using spring tools with cuts that took up to 28 hours. At GE those holes I cut across were on a 6ft diameter and the machines were all Bullards. I've had a catch or two with gouges but I've never had a catch with a scraper. I agree there will be a burr there for awhile but I use that scraper for a long time after that burr is gone and it does me just as good as when first sharpened. No matter how good the finish is off the tool the piece is still going to see some sandpaper. I highly suggest that Steve Tiedman's first paragraph as there is a lot of good knowledge in that short paragraph.
Thanks for the kudos, Bill.
And watch those fingers, everyone!
dangerous habits...... That's part of the reason I don't watch raffan videos. Early on I thought to myself he does some unsafe stuff. Seems like a lot of "older,experienced" aren't setting good examples.
Woodturning is dangerous by its nature, and as an instructor of rank beginners (well over 200 so far) I intensely emphasize safety. But I'll guess that there isn't one veteran production turner around who turns off the lathe EVERY single time they move the tool rest. The key is to know what your level of risk is (e.g., a natural edge bowl vs. clean spindle or bowl, or how close to the wood you're planning to set the rest. Students are watched carefully that they they follow the "rule" to turn off the lathe, and fear instilled, but no expectation that after dozens of hours of experience they will stick to it 100%. I sure don't.
I might not turn off the lathe just to raise or lower the tool rest as it's not in the way of the piece. I do turn it off when moving the banjo (why do they call it that?).
Can you be more specific on what safety risks you perceive?
I'm also curious about some specifics. I've watched Raffan at a club demo and on videos and failed to note anything I considered dangerous. Maybe I wasn't observant enough.
Of course, MANY things are dangerous to some people starting out with no experience, limited training, and who don't read the turning books and literature. I've seen a self-taught turner or two do things that made me nervous. I am quite wary of youtube instruction from random turners - I've seen so much bad technique and unsafe practices.
Sure, most types of turning have hazards. But so do driving a car, landing an airplane, kayaking on big white water, rock climbing, racing motorcycles, operating a table or chain saw, deep scuba diving in caves requiring decompression, canning peaches, antagonizing the wrong person, or even embroidery.... In all you learn techniques, learn the hazards, practice/practice/practice, and always remain alert.
Tool rest height can change as one turns a piece of wood and the tool used.
What kind of turning do you do?
I'd be interested in your more detailed reasoning with this concept....
Note that the centerline of the spindle's distance to the bedways are the same in either case.
I'll also state here that this isn't a "gotcha".....just interested in your thoughts here in more detail.....
=o=
=o=
Its common to have the rest high when using a skew chisel, which may change as the diameter is reduced.
Or with scrapers raising the rest to help keep a <90° angle with the wood.
I defer to Ross's answer.
OK.....just wondering. I was not considering spindle turning when I asked.
For bowl turning, I find the same height for both scrapers and gouges works best for me.....:)
=o=
I change the rest height often when turning spindles, depending on the diameter of the spindle and what I'm doing, planing, coves, etc.
As for the skew, I've experimented with a variety of too rest heights. I tend to have it lower than some I've seen. One demonstrator, without a lot of experience based on his work, used the skew with the rest very high. A friend and I noticed his arm position looked strained and his back stiff.
With the rest and skew high, it's not easy or possible to support the skew as well for thin spindles: held in one hand, handle firmly against my forearm, further support by the side of my torso. And more importantly, it is more difficult to do the spindle-turners "dance", moving body with the knees and not the arms. Without this, I think smooth, flowing, fine tool control is more difficult. Maybe far more difficult. When I have the tool rest the "right" height (for me) things are easier, cuts flow smoothly, much less sanding needed.
This is based on things I do without thinking now. I'd have to repeat the rest height experiments to describe all this more clearly and remember other advantages/disadvantages.
BTW, I too (think I) keep the tool rest at about one position for face work, bowls and platters. When I change the height it's mostly when switching to a thicker or thinner tool, say from bowl gouge to NRS.
Tool rest height isn't a precise measurement. For turning, I might tweak it a couple of times before turning, using the diameter of the wood and the tool presentation.
YES! The dance!
Not everyone talks about it, but it is so important in obtaining good tool control.
If I am having "a bad day" woodturning, there is a list of things to check:
1. Sharp?
2. Tired?
3. Stance and ready to dance.
Stuart Batty is great at teaching and reminding folks to prepare to do the dance at the lathe when they turn. Stance is the key word on his turning checklist.
I used to recommend the "Bowl Turning" DVD by Dell Stubbs. Long outdated even by time I found it, It was still a gem because Dell explained the dance so well.
A much more recent and quality DVD that I now think is the shining example of this is Bill Grumbine's DVD "Turning Bowls Made Easy"
If you want to help a new turner get past the noise of YouTube, Facebook, and Instagram, Suggest the DVD "Turning Bowls Made Easy".
Oh... and the best money I ever spent on woodturning? (After the purchase of my lathe.)
A hands-on class with Stuart Batty. And a close runner up is membership in my local AAW chapter Front Range Woodturners.
YES! The dance!
When I teach spindles I turn the lathe by hand until the person can make continuous fine shavings. Then I explain the movement - how and WHERE to place the feet, how to bend the knees, and how to move the tool with the body rather than the arms. I watch carefully and correct everything that needs correcting. For some, I have to remind repeatedly to move with the legs, not the arms. Only one person in dozens never really grasped the concept.
To set up the legs for a planing cut with the skew, I have them position the skew at the END of the cut (all with the lathe off), then position the feet so the stance is comfortable. Then bend the legs and body to move the body towards the beginning of the cut and start the lathe. This way they are starting from a bit of a stretch and ending up in the most comfortable position. I think this is better than starting from "comfortable" and ending in a stretch.
John Lucas is another who emphasizes body movement while turning. However, we Baptists aren't supposed to dance. 😇
John, your last paragraph is on the money. Good way to teach. Need to review my own turning.
.. However, we Baptists aren't supposed to dance. 😇
Just sing loud to the heavens and move with passion. It might look like dancing but it's joy - might be infectous to those around. I was usually quite loud in the congregation - I thought maybe TOO loud until a woman turned around and told me she loved sitting in front of me during the singing! (Who knows, she might have been lying or partially deaf ...)
And I claim to move at the lathe as practice for playing the piano vigorously while standing! Movement in both is essential. Slap that wood. Slide that skew! (I keep a piano in my shop to work on improvisational hymn-playing. It's a leap from the classical I was trained on but gradually improving. I'm trying to learn to play whatever I can hear in my head.)
I've been in plenty of Baptist churches where the music makers weren't made of concrete - guitar, drums, sax, trumpet, etc. I even moved quite a bit as part of a woodwind quintet on stage - all five of us were all standing and moving - I was groovin' with my french horn. Dancing? don't know... But I can't play if I'm super glued to the floor.
A good friend and I did several live improv duets on stage - him on trumpet, me on piano. We'd practice some snippets and the general flow at home but we never knew where we would go in the music until it happened. On a whim I once started "It is well with my soul" with a thunderstorm in the piano bass (a nod to the tragic and beautiful story behind the song) moving up to a arpeggiated mellow transition with the trumpet coming in with "when peace like a river...". Better believe I was "dancin" during the storm while on that bench! Playing together through that song almost made me weep.
And I claim a license to move - at home I have the concert bench Billy Joel sat on when he performed in Knoxville in 1980. THAT guy liked to move! (wishing him well with his current health issue)
Back to tool rest height. We had a demo yesterday. The woodturner was constantly moving and adjusting the tool rest. He was making a lidded box with all kinds of cuts plus a finial.
Tool rest height is obviously not much of a consideration for many turners......and it's also very obviously important to a few other turners.....like myself!
The reasoning is based on the results required. :)
If the final shape is devoid of finely crafted turned details, then the quality of the cut isn't as important.....mainly because turners these days rely on power sanding to bring the surface to a presentable final finish. If many finely turned details are the objective, then avoiding power sanding is one of the most important considerations. *
(* Of course, this depends on other things as well.....like sharpness, tool presentation, best vibration free rpm, etc.)
=o=
It would work great! Fantastic! Incredible! If, there’s that big little word, if, you only used on height and never raised or lowered your too rest, changed tools, and spindles size was consistent. What about bowls?
Bowl turning is all I do.....
I also raise and lower my tool rest height frequently....mostly when I change tool thickness.
Click on the "My AAW photos" link below to check out my work....this will give you a perspective of what inspires my conclusions. :)
=o=
I probably worded this thread wrong because I tend to get wordy and people cant/don't follow my line of thought.
Jump back to the number ten post,this for me is an easy way to make sure I'm able to see the center line of the piece accurately (mostly cane shafts) for a double check after tool change or rest change,I do have stop collars on my tool rests which limits how low they go and then I get more accurate movements by sticking my index finger under the collar while tightening the lock.
AND.....wth, it's one of the cheaper non essential tools I've spent money one. Probably got my money's worth in entertainment value.
Adjusting a tool rest to the drive center height needs NO extra tools and will indicate the exact center line of a piece. Maybe just me but, I like free better than $7.00.
If I'm understanding you correctly, all your turning is done above the centerline of your workpiece?
=o=
=o=
Yes Odie, over 99% of the time when doing spindle work. My reply to Sam's post was just about setting the tool post to the axis without using any other tools.
