Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Jim Hills for "Journey II" being selected as Turning of the Week for May 6th, 2024
I have a holly vessel that I have turned that had already stained before I turned it. If I use wood bleach on it will it bleach the holly back to the typical white color of holly? Or would I be better off leaving it as is.
Stained with what? If it's mildew, bleach should take care of it. Works less well with stains from spalting fungi. The sugar (caramel?) stains that come out when green wood is spun are best washed, sanded and washed, in my experience.
I recently bleached a holly vase that had turned blue/green, and it came out several shades lighter - almost pure white. I used the Kleen-Strip 2-part bleach, and gave it 2 treatments. I'm very happy with the results. It did raise the grain, so it's a good idea to raise the grain first and resand before bleaching. The bleaching doesn't go too deep, so be careful when you're sanding.
