My new 3520C Mustard Monster is here!
That one is available from Amazon, too. Can you update when you get it mounted? All the reviews say the mounting screws are too small/short. Hmmm, probably an easy fix for a woodworker!
my favorite negative reviews on this were the ones complaining that it was too difficult to use. They had to mount it to a table because they couldn't use it handheld. Or the one that says it requires two people to use it. I really get lots of entertainment reading amazon reviews
I went from a Laguna 15/24 lathe (sold) to this Powermatic 3520C .
One thing I was pleasantly surprised with was the quill on the tail stock is much more solid and precise ( no play side to side or up an down) on the powermatic.
My Laguna was loosely goosey and with out knowing any better I just accepted it, I am hoping my pepper mills will be much more accurate now with the drilling of the stock
I had the same Laguna as you and upgraded to the 3520c. I had no problems with the Laguna in the 2 1/2 years I had it, but I just outgrew it and had put a lot of hours on it. These two lathes aren't in the same category, I considered the Laguna a midi and the Powermatic a full sized lathe. First the Powermatic is more than double the weight of the Laguna and size. Second you are correct, fit and finish are better on the Powermatic. It handles drilling pepper mills very well but I do use a steady rest to help hold them perfectly on center when drilling. I called yesterday and they are shipping the control button cover.
That x-acto model looks very similar to the vintage Boston sharpener that has been with me for almost 50 years now.
When I sold the business and retired a decade ago from daily work in the design firm I started 40 years earlier, one of the things I took with me was a pencil sharpener that I had bought used and used nearly daily. It’s a Boston Ranger hand crank with six pencil diameters it will handle and a selector for three lengths of lead…it is an awesome tool if you spend time with a sketch pad.
It hangs on the wall beside my small working desk in the shop.
They are. You probably have the right screws in your shop. You will need more to mount its replacement in a couple of years. Ask me how I know.😕
How do you like it so far? I am in the market for a lathe , just haven't decided which one
In my opinion, if you are good with a sliding headstock, and possibly cast-iron construction motivates you as well.......you might find similar lathes, but you won't find a better lathe than the 3520c.
Can anyone tell me if the 3520c banjo can be purchased separately? For those of you who have a 3520c lathe, can you tell me the overall length of the bottom machined surface?
I am thrilled with my new rotating headstock Vicmarc VL240 lathe, but the banjo sucks. I'm thinking the 3520c banjo might be a great replacement with its pinch style of securing the tool rest post.
=o=
I was using a Laguna Revo 15/24 for about 3 years before pulling the trigger on the 3520C Mustard Monster.
I have several turnings featuring this lathe in the "whats on your lathe" thread on this site to see some of the items I am turning on this machine.
So far this lathe has exceeded my expectations. Very stable , Very powerful, Fun to turn on.
I have turned large bowls to tiny lidded boxes and it doesn't matter what goes on it, the lathe is one smooth machine.
Very hefty though at 726 pounds and mine is in my basement. Had to have another help me bring it down in sections.
If you can get one on sale, like I did, it is even a nicer machine.
So Far Powermatic as a company has been very pleasant to work with.
Whew that was alot.
If you decide to get one you won't regret it for even a second.
Good Luck!
Mine didn't come with the rubber switch cover. I have about 100 hours on my lathe and haven't had any problems yet with the switches but I vacuum the lathe off every day after use and make sure it vacuum the switches and vfd very well. I'm going to call and order the cover someday when I remember.
Mine didn't have that cover either, someone here mentioned you could contact PM and they would send you one. I sent them an email and they sent the cover pretty quickly.
Oldie, the length of the machined surface on the bottom of my 3520c banjo is 18-3/4”. The height from the bed to the top of the banjo is 5-7/8” +/- 1/16”.
I would think you could buy it separately but would probably have to call Powermatic.
Also I’m fairly certain Robust has the same locking mechanism on the banjo as Powermatic.
Thank you very much David......:)
The Vicmarc banjo is about 19" long and 6" high.
I think the PM banjo just might be the ticket! :)
The Robust Sweet 16 standard banjo won't work for me, because it's not a dogleg shape. (I have the alternate Sweet 16 banjo, which is a dogleg style, but it's too short to work with a swiveling headstock.)
=o=
=o=
Oneway have nice banjos - I fitted one to my Jet 3520B and was very pleased with it.
Yes the Oneway banjos are outstanding, but not a dogleg shape......I NEED that! :)
=o=
I am putting this data here for you from another thread I posted in. Sorry for the late response.
PM standard banjo for 3520C
H= 5 3/4 "
L= 18 7/8"
Stick out = 10 5/8" and 10 3/4" (Travel from center line of lathe with being flush on the bed ways)
H= 5 3/4 "
L= 18 7/8"
Thanks for the information, Greg. :)
If I decide to get another banjo for my VL240, the PM banjo is a serious contender...
=o=
Are you kidding me??? All this talk about sharpening pencils and it hasn't occurred to anyone that you have the perfect tool for sharpening a wooden pencil? Let's see, what could you use to spin a piece of wood and touch a sharp cutting tool to it? We should be doing the fanciest pencil sharpening jobs in the world! :p
