Most of my turning is kiln dried black walnut. What angle would you use?
Why not just use a 600# wheel?Hi Tim,
I grind on an 80-grit CBN wheel, then hone with the 600-grit diamond hone in contact with both the cutting edge and bevel heel to produce an effectively flat bevel. Your edges are coarser with hollow-ground bevels. Hollow-ground bevels if you're traversing in a straight line demand more clearance which is undesirable. Also because it's serrations are finer, my honed edge will last somewhat longer than yours.
If you hone, you can resharpen several times just by rehoning before having to regrind. This is quicker than having to reset your grinding jig to accommodate a tool change and then regrind.
The bowl gouges I use when hollowing all have convex bevels. I also use a ring tool. I always hollow outboard. When you have done so you'll never want to hollow inboard.
Best wishes, Mike Darlow
Are you turning spindles or bowls? For spindles, 25 to 30 with a skew, for the SRG, mine is at 40. I would use a 40/40 grind on a bowl gouge for a platter, and a 40/40 and a BOB (bottom of bowl) gouge for the transition and across the bottom. I am making some boxes now, and roughed out 2 blanks, 2 or so inch square and 3 inches or so long. I roughed and finished with the skew. I don't turn walnut much any more because it makes me sneeze and itch. I have found peeling cuts to be far faster and more efficient when roughing down spindle blanks.Most of my turning is kiln dried black walnut. What angle would you use?
Maybe I missed it but I didn’t see anything about grind angle differs with wood species/hardness and green vs dry.
Should another element be added into the discussion be considered regarding what is being turned?
I haven’t even heard about the carbide cutter described by Doug Rasmussen. The rounded tip would make achieving sharp cusps and sharp junctions difficult, if not impossible. And how readily could the tool be manipulated to produce the full vocabulary of possible turned forms?
Robo, I’m so glad to see you say this. I’ve just worked through a batch of walnut from a large tree (about 22” in diameter) that’s been down for a couple of years near me. I’m happy with the results but was sharpening the chainsaw and the gouges like never before. I suppose it’s high mineral content in the wood, but whatever the cause, it was quite a chore. Not so bad to go back to the grinder with a gouge in the shop, but when you’re off in the woods with a saw that is quickly losing performance, that can get demoralizing.For what ever reasons, walnut seems to dull all tools faster than most other woods, from chainsaw to scrapers.
That's a good reason to take multiple sharp chains to the woods and use a grinder in the shop to tune them up.Robo, I’m so glad to see you say this. I’ve just worked through a batch of walnut from a large tree (about 22” in diameter) that’s been down for a couple of years near me. I’m happy with the results but was sharpening the chainsaw and the gouges like never before. I suppose it’s high mineral content in the wood, but whatever the cause, it was quite a chore. Not so bad to go back to the grinder with a gouge in the shop, but when you’re off in the woods with a saw that is quickly losing performance, that can get demoralizing. View attachment 78719
Therefore I believe that the AAW needs a new direction. It needs to: recognise that there are optimum techniques in bowl, cupchuck, faceplate, hollow and spindle turning, and promote them; encourage a wider range of subjects for turning; and encourage debate in American Woodturner so that all the membership can be informed.
Bill, After much of my woodworking life focusing on building small boats, I was simply running out of room in my little 20’ x 22’ former garage shop. I built about 7 kayaks, a strip built canoe, two standup paddle boards, a small trailered sailboat and two Adirondack guide boats (see my avatar picture). Boats hanging from the ceiling and on racks on the walls, I was simply out of space. I thought that turning, which I had already dabbled in, would take up less space. Hah, how naive! Between the supporting equipment, and hundreds of drying bowl blanks, plus shelves for completed bowls waiting for a new home, my space is tighter than ever. But I’m hooked, so no going back. I love wood, and love the way we can gather our raw material all around us. I’ve developed a reputation in my neighborhood as the turning guy, and when anyone is having arborist work done they give me a call, knowing they’ll get a bowl out of it. It feeds my soul.Let's answer a question here. What attracted you to woodturning? Please everyone answer.
My uncle had a harbor freight lathe. He was making baseball bats and pens. Once I gave it a try, I learned how much I enjoyed it.Let's answer a question here. What attracted you to woodturning? Please everyone answer.
I'm not a paid member, so I do not have the right to vote. But I see your point about this, Mike, but I didn't leave because of perceived, or real failings on the part of the AAW. I left because our interests diverged.I started turning after chancing on Peter Child’s book in a library. The combination of being able to make things, an interest in tools and equipment, in design, and understanding the process was and remains attractive to me.
I started this debate for the purpose of changing the AAW so that it better serves the needs of the bulk of its members. The posts of Steve Tiedman and Reed Gray illustrate the failings of the AAW. There’s going to be a new Board and a new editor for American Woodturner. In my last post I suggested how you could make a difference. Not much sign though that anyone is interested.
Well, what attracted me, I don't really know. I always knew I would end up working with my hands.
You probably would have been a great one if your turning knowledge is any indication.Interesting comment Mark. I have always thought that if I went a different direction, I would have been a chef....
I'm not attracted to the traditional processes of woodturning and tool sharpening, etc.Let's answer a question here. What attracted you to woodturning? Please everyone answer.
My interest is more in the design of "turning-like" objects. And in the ways of making them easier than traditional turning. I'd prefer the AAW (as reflected in this forum) was more open to more non-traditional methods.
