Catalpa(?) crotch, about 3" x 10". Whatever it is, it's soft and fuzzy. I managed to get a decent surface with a skew chisel, then proceeded to break the tenon when the hollowing began. I saved it by sawing off the tenon fragments, cutting a tight recess in a glue block and centering the natural edge mouth with a tapered tailstock extension in the 1/2" pilot hole. I like showing off crotch figure in a (very) slightly tapered vase form.
This was on lathe today. Finished it today, but needs more oil. First time with Goncalo Alves.
Alan
That's a bowl form that is not seen so often. I like it!
It exposes more of the side grain and makes the best of that orientation in some species and pieces of wood.
I do a version of it myself, but like yours execution of it better.
Black Limba (Terminalia superba)? I got some from a dealer in Atlanta years ago, turned a couple of things. Easy to turn but kind of soft.
From what I understand, Limba is Limba. "Black" Limba just has more dark color and figure, and is generally prettier wood. The little 4-inch square trays I make with it just fly off my table at shows (probably because they're the least expensive trays I make). And yes, it is really soft, and quite chippy in my experience, thus requiring light cuts with razor-sharp gouges.
Beautiful, Odie! And getting those consistent accent grooves with all those interrupted cuts must have been tricky.
Thank you Aaron..... :)
You're right! I was optimistic, but concerned while doing the grooves. To tell you the truth, getting a clean cut on the surface prior to doing the grooves was even more challenging. Not to mention sanding those surfaces. Sanding there was done off the lathe and completely by hand. Doing any sanding while rotating on the lathe was impossible without rounding over the leading edge after the void.
=o=
See what happens when you leave a platter alone in the dark..... still trying to keep my sister busy, 1/8 inch beads. maple, didn't measure it.
My daughter and I had previously done a redwood burl collaboration that was quite a challenge, but turned out well. (Post #5,147) I had another piece of redwood from the same source. This piece had some voids, cracks and worm damage. My personal belief was that it would be fun, but dangerous to turn. My suggestion was whittle it down and get a small shallow bowl. My daughter, on the other hand felt we should go for the gold and turn another piece similar to our last burl. She called it "L'appel du vide" which is the French term for "the call of the void," a psychological phenomenon where people experience a sudden, often unsettling urge to jump or do something dangerous, even though they don't actually want to die.
We started hollowing the piece in-order to get some of the mass off the top so we could increase the turning speed to get rid of some of the air. We wanted to end up with a lace type natural edge assuming it did not blow apart on us. We eventually got the upper edge thin enough so we could blow out the bug goop and reinforce the surface with thin CA. My daughter said it was held together with hopes and dreams and CA.
We were having some real good luck at this point and felt confident. I set up the hollowing jig and we proceeded to push the envelope. The wall thickness is just under 1/4 inch. It is now ready to pull off the lathe and do a little finish hand sanding and apply some Watco Danish Oil. It has been a great collaborative project. Both of us pushing the other to exceed our capabilities and push the envelope.
View attachment 77908View attachment 77909View attachment 77910
That sure is an interesting piece of wood. It's got a bit of everything.
And another one down.
11.75 x 1.75 maple (probably silver)
I was going to bead the top side but it sanded so nice I didn't want to rough it up. Oh well. There's always the next one.
**EDIT** other two pics I added are after my sister got through with it today. She seems possessed keeping ahead of me.
Looks interesting. How did you turn the outside of each pot?
Only the tops can be turned, using a scraper. Most of the rough shaping is done with grinders held in a compound vise supported by a banjo. I use an overhead mounted template and laser to mill the pots as close to identical as possible. Hollowing is done as usual, but complicated by the imbalance of the piece.
I braved the 105* heat index today to turn a bowl. I was getting the jitters since it had been a couple days since I was in the shop.
This bowl was supposed to be something else entirely but since that didn’t work out I listened to the wood and it wanted to become a bowl with a slightly enclosed rim, 12” x5”.
I don't know what the original plan was, but the reimagined piece is outstanding.
Oh, and the heat. It's a little unbearable right now, for sure.
