Was just about done with a beautiful piece of ash when I messed up—too thin on the bottom. Too pretty to throw away. Got to figure something out.
I would try a slurry of wood glue and sawdust plastered to the inside. After it cures you may have a second chance without the outside looking carved up.
I put it in a donut chuck, made the opening bigger, and filled it with this piece—desert ironwood, I think. Will try to finish it this weekend. Could draw a face on it—looks like the Jack in the Box character IMG_2858.jpeg
Completed Cherry wood lidded box.
(Jimmie Allen style)
Finish: Sanded to 600 grit, sanding sealer, Yorkkshire grit, followed by Dr Kirks polishing wax.
Just started my first Jimmie Allen design lidded box out of some very dry cherry wood.
Many steps in the process but this is my first attempt.
End result is very nice, Greg. My question is why are you using so much wood? Seems like you could have used just half or less of the length and achieved the same result .... and, be closer to the headstock. Is there something I'm missing about a Jimmie Allen design?
Thanks , there is almost no wasted wood. What you are seeing is the use of maple glue blocks and a mandrel on the headstock on both sides of the cherry blocks. In fact I used almost all the wood for the base and only about a qtr inch was wasted on the lid. I was able to make a jamb chuck out of it.
Greg, I do use waste blocks for all the threaded boxes I do, but not for the slow drop boxes, what I call my 3 to 5 second boxes, since it takes that long for the bottom to drop off if you pick it up by the lid. That may actually be more efficient than using a small tenon.... Have to ponder this one.
Small Wenge Lidded box.
If anyone out there has ever turned Wenge you know how easily it chips out and brittle it is..
Tried to minimalize the chip out on the beads but wow what a challenge.
You sure are versatile. I’m a one trick pony but you keep coming up with new and varied items. It’s impressive.
Thanks! I started out making furniture for myself way back when, we were just getting started as we couldn't afford any. Made these cabinets in my office/ computer room. I also did carpentry work. Have done 4 bathrooms and 3 kitchens.
Maybe if I stick to one thing I'll get as good as you!
