I’m on a journey to turn a true sphere. Plenty of guidance on u tube, but not so smooth in person. This is 2 inches diameter. Started as 2 1/4. Crabapple.
Good fun! It looks like you're well on the way to a perfect sphere!
Mark StLeger showed a nice trick to help refine the sphere. He cut a short piece of what looked like PVC pipe straight across at exactly 90 deg and smoothed the end. Seems like the pipe was maybe 1/2 the diameter of the sphere.
When at the stage of holding it on different axes with cup centers to refine the curves, as it looks like you are in the photo, he holds the end of the plastic pipe against the wood and moves it around on the surface to see where it needs work. When the pipe fits perfectly all over, it's done!
He turned these in a demo at a symposium, turned a round track in a piece of Corian so three spheres fit perfectly. When the top one is spun, all four go round and round! I'm honored to have this one in my display cabinet:
Many years ago I devised kind of a variation of the pipe check method, not to check, but to turn some spheres. I used a piece of steel pipe a little smaller than my intended sphere. Spun the blank on the lathe while swinging the pipe back and forth on the tool rest, sort of like a circular scraper. It quickly transformed the cylindrical blank into one with a marble-sized sphere on the end. It was so easy it almost felt like cheating!
When turning larger spheres I start with the octagon method like you probably did, then successively trim off the "corners", approximate the curve with a spindle gouge, then hold between the cup centers to refine.
During the 2025 AAW Forum Holiday Swap, Don Frank and I agreed to swap some wood. Don sent me a Cherry Burl and a Persimmon. I decided to turn the Cherry Burl first because Don said the Persimmon might be a little wet.
View attachment 84606View attachment 84607View attachment 84608
Jay, It's good to see you have some of it on the lathe. I haven't done anything with the pieces you sent yet. I'd rough out the persimmon with the idea of twice turning it. Otherwise it might be a while before it gets completely dry. In the meantime your shop will smell good with the cherry burl.
Don, I will follow your advice on the Persimmon.
The Cherry Burl does smell great. However, it is proving to be a very challenging piece to turn. Sharp tools are a must.
Be advised that wet persimmon is one of the most warping wood I've had, almost as bad as green holly. I've had boards from the sawmill twist and crook until they were unusable except for small things. Dry persimmon is fine. (Persimmon is wonderful wood to turn - hard, fine-grained, cuts lie glass). BTW, it's a species of ebony)
I cut up some more wet persimmon on the bandsaw recently. I seal well with Anchorseal, sometimes on all sides (depending) and let it dry for at leaast a while or until totally dry until I use it. Even square blanks warp significantly as they dry, depending on where they are cut in the log and how and where the rings cross..
Persimmon is best cut in the winter to help keep it white. If cut when warm, it will often quickly develop brown/grey streaks which don't look bad.
These are persommon:
Unlike black ebony, persimmon usually has just a pencil-thin streak of black in the middle, sometime more like one of those boxes. Occasionally I'll find wood like this. When I do, I hide it from woodturners:
It is a beautiful piece of Persimmon and I have more than enough wood to keep me occupied for sometime. The piece is flat on one side and sealed well. Right now I’m battling a California winter with temperatures dropping to the high 50s and low 60s. In a few months summer will provide kiln temperatures for the garage. I can wait until it has had a chance to dry well. I will try and listen to your advice and not jump the gun.
If you weigh it every few months when the weight quits dropping the blank is dry. I write the weights in grams and dates on a piece of tape, like this.
I bought several of these just to weigh wood..
www.amazon.com/dp/B07QP4XQNV
John, you are correct on how much the green stuff moves. I tried some once turned hollow forms out of the stuff and they are oval or split. I had quite a bit of it so I chunked it up and "ponded" in 55 gallon barrels of water it for 9 months until I had a chance to mess with it. It did not smell good when I finally dumped it out and power washed it clean. Michael Anderson can attest to wonderful smell but once they were cleaned up they were fine. Persimmon is in the Ebony family and an acquaintance who imports Ebony has to go to great lengths to dry the stuff in thick beams. More difficult than any wood he deals with. I have been air drying some 5/4 that I cut up on my sawmill. It's about time to kiln dry it and see what I have.
you are correct on how much the green stuff moves.... persimmon...
BOARD WARPING
There are a lot of factors that contribute. Holly is another one where I've seen extreme warping. This small board was cut green on my bandsaw:
When I actually worked for a living I did a lot of analysis on various things. I decided to analyze the way green wood warped, inspired by R. Bruce Hoadley's book "Understanding wood" and some other more technical references. (My library outgrows my shelves.)
I made 3D models of boards cut different ways from the log. Based on the tangential to radial shrinkage data in the Wood Database and elsewhere, the location and angle of the grain down the board and some cross sections of the rings down the length, and some observation/past sawmill experiences I did a quick analysis.
I think I started to figure out what was going on and could predict whether an unconstrained wet board would twist, cup, etc. as it dried. The diameter of the log matters too since a small diameter can have a greater amount of the less stable juvenile wood (board closer to the pith). It was fairly easy to visualize with the graphics but I think now that graph paper would have worked as well.
BTW, I stole this handy illustration showing the terminology of the common board warpage.
Those who have sawmills know how important to sticker and weight stack of freshly sawn boards. (I use a bunch of concrete blocks) For short, thin boards I cut on the bandsaw I sometimes sticker and use clamps. As the wood dries, the stresses from shrinkage stabilizes somewhat. Heat from a kiln does this faster. (One exception is Eastern Red Cedar - If not too thick I would often lay the freshly sawn boards out in the sun on top a flatbed trailer, flipping them over several times during the day as I saw them start to cup. It was surprising how fast 4/4 boards dried and dried flat this way!
If I saw ERC 8/4 or thicker, I do sticker and work on my patience.
Here's an example of the T/R shrinkage in a piece of Dogwood. I had rough turned the box and lid and did the usual - put it up for a few days to let the stresses equalized. In this case the wood must not have been completely dry! In this photo of the lid the radial direction is vertical and the tangential is horizontal. The upper part is getting into the juvenile wood where all bets are off - a bad decision on my part. The gap at the caliper shows the the difference in shrinkage between the radial and tangential! I didn't leave enough wall thickness to fix it so that's one for my Box O' Shame!
Dealing with limbs and reaction wood is interesting. This is from a cross section of a big oak limb near my barn which somehow grew almost perfectly horizontally for about 40'. Would have made a great swing limb! When it died I cut it up and counted about 100 years of rings in the limb! I suspect the best way to mill that would have been to get a nice quartersawn board or two. I do wish I'd taken the time to cut some turning blanks. :(
There's no wood that warps more or faster than a Home Depot 2X4
Yikes, that's terrible. Don't know about others, but our HD has several grades. I buy the better after picking though the stack. They sure are cutting construction lumber from tiny pine trees now.
A far better place around here is Builders FirstSource - good supplier of quality kiln-dried dimensional lumber and much more. They cater to the construction industry but will sell to anyone. Yes, prices are higher but for some use that doesn't always matter. Also, when I want good plywood I go to a place that sells to cabinet makers. Best place to buy 5x5 sheets of baltic birch.
When building my shop I also found one large local lumber supplier who would sell 4x8 sheets of ply for a huge discount if the sheet had even a small ding on the corner or face. I walled inside my shop with $5 sheets of 1/2" smooth Radiata pine ply. I prefer ply since I can easily mount shelves and things anywhere.
I will never forget going to a lumber yard to get some 2 by 4s for setting up a curved step/wall forms. I had to complain to the guys inside that I could only find straight ones. Even if you buy kiln dried, most will store it outside and moisture content goes back up to 15% or more, depending on your local weather. I make sure to acclimate my wood before doing anything with it.
A bit under the weather, but got out to the shop later today to turn this dried flower vase out of a piece of holly. Photos off by 90 degrees again 🤔
Video of it on a Lazy Susan:
Nice! I couldn't get the video to play (wanted me to sign up for Dropbox) but I believe it's great. :)
I like how you softened the sharp edges.
Did you upload those photos directly from a phone or ipad? Found that if uploaded as an Attachment the forum will cause that problem in some cases. Has something to do with the internal exif data and the original rotation of the phone camera. I uploaded with "Insert Image" photos might display correctly. (But I never upload directly from a phone.)
I rotated them just for fun:
Click, then click again for enlargement. (at least on my Win10 laptop)
Nice, that’s on my short list to try in the near future. Hopefully my machine can handle the off axis turning without walking across the shop or shaking itself apart.
What kind of lathe?
Nearly any should be OK since these pieces are usually not large. And since turned on three axes it doesn't really get much out of balance. If in doubt, start with some lighter weight wood like poplar or cedar.
For anyone not familiar: the late Brian Horais was a master at this - lots of photos in the gallery here. Somewhere I've got his instructions on paper but I can't find a file. However, I see the person using the method has some of Brian's diagrams in this video, starting around 1:15. This guy doesn't make a full length twist but the idea is the same.
View: https://www.youtube.com/watch?v=YXu51VkLoug
What kind of lathe?
It’s an old 4 position pulley Delta lathe from the 60’s. I have it weighted down with a bunch of wood drying for future projects. I turned the cylinder last night and we will see how it goes this week.
Bob
Snow and ice have been cleared and had a couple of hours to finally get back in the shop. It’s been two weeks since I turned anything and going through withdrawals….holding a bowl and a hollow form in my arms while sitting in the recliner at night with a blank stare!!
I had just a couple of hours free today so made my wife a salt cellar.
Had a small piece of birch burl from a large root burl that my brother got about 35 years ago. He made several pieces from it the largest being a low table with a top about 3' around natural edge.
IMG_1811.jpegIMG_1814.jpegIMG_1815.jpeg The cup like bowl is about 3" diameter X 3" high X 1/8" wall and I finished it completely in one session. The fit on the jam chuck was so good that it ran true and stayed in place when I backed off the live center,than turned away the remaining nubbin
Still have a bit of tearout to deal with, some spots are a bit punky.
You mean fingernail gouging punky? I turned a bowl like that once - stunning spalting but well on it's way to rot. I ended up strengthening/stabilizing the soft areas (all the way around the bowl) by soaking with thin CA glue, a little at a time letting it set up before adding more until it was saturated. I had to use several bottles. (no accelerator) This stopped the tearout and hardened the soft stuff so the whole thing now is like good, solid wood. (sorry, didn't get a picture yet.)
I had another piece of spalted wood sent to me by a new turner, said it had sentimental value to him as it was from his mother's yard. It too was so punky that big soft chunks would come out of the blank with a fingernail. Again, thin CA glue let me complete this easily. I soaked with CA a little at a time, let it set up, added more until it was saturated. Turned a little, repeat. (IIRC this piece is less than 2" tall.)
Not that punky. More of I couldn't get a clean cut or shear scrape all the way around. I'm using my regular finish, Danish oil to harden the surface more. I have the tear out gone, but need to do some more light sanding to get a smoother finish between the hard and softer grain. Something I can feel better than see at this point.
Pedestal dish.
Made from walnut and an unknown hard wood. 8 1/2 diameter by 4 high.
Friction polish for now. Still needs to cure. Not sure what I will use after. To cold in the shop to rush things.
Not sure on the thickness and shape of the foot?
View attachment 84889View attachment 84890
Hi Phil. I’d suggest the base could be a bit thinner and streamlined. These are cake platters but the same base would also work well on a bowl like this. IMG_2167.jpeg
