Going to start with this one…
and down the rabbit hole he goes . . .
Forgot to take pictures while on the lathe, but these came off in past couple days. First is segmented piece using aspen, wenge and black dyed veneer. 16 segments per row plus 16 veneer between each segment, total of 17 rows for 527 pieces (bottom is a single piece of wenge). This is 6-3/4” tall x 3-1/8” wide and 3/16” thick.
Second piece is cherry from a tree we took down. I’m playing with this shape, but something’s off - I’ll keep working on it. Piece is 4-7/8” tall x 7-1/4” wide and 3/16” thick.
Tried turning a Camphor live edge. Was on my last piece of sand paper when it caught in the hole and tore the sander out of my hand. This broke the live edge off and turned it into .......
View attachment 75193View attachment 75194
You can take your sander and make your own natural edge with the broken part. Just blend it in with the edge that’s not broken.
However it looks fatter in the photo but not in person.
Maybe try moving the camera back and either using a longer lens if you have one, or zoom in a bit. (Or just take a shot from further back then crop in an image processing program to get the framing you want.) Up close with a wide angle can cause more distortion. That's a common method for portrait photography for several reasons, one, a more flattering perspective of the subject.
I think I take the photos to close up and need to zoom out some. It’s amazing how different it looks compared to the photo.
When you take the photo your eye adjusts to the perspective or real look. The lens changes this with things like depth of field and distortion of the image such as fisheye (common in closeup lens use). Like JKJ said you can adjust some of this effect in programs and sometimes even with the software on your phone.
I’ll play with the phone and see if that helps.
Just to be clear, don't "zoom out" which won't help with the perspective (if you mean what most people do by "zooming out"), but physically move the camera further away and either zoom in (magnify) to frame the shot or crop the photo.
All this can be quite confusing to someone used to thinking in terms of focal length for film camera! What's worse, some phone cameras switch lenses when you zoom in and out (actually, they can seamlessly switch cameras - the technology is exploding).
Fortunately you don't need to know any of that. Just back away from the subject! Fortunately for us, the image resolution on today's digital cameras is incredible compared to what we used even a few decades ago.
I even shot a magazine cover with a phone camera over 10 years ago - I still can't believe the quality even then. We are so spoiled today.
The suggestion I got from a teacher was to set your smartphone to 2x or 3x zoom to get a better picture.
Good instruction! That will force you to not get too close!
Another reason for a longer (“ or zoomed in”) lens that can apply to woodturnings - the depth of field is reduced, blurring the background (depending on the lighting, of course) With this, focus is important, sometimes difficult when shooting things that move. A couple of examples, where the background vegetation would be distracting.
BTW, another reason to take portraits of people from a little further away is to make the model feel less “crowded” and more comfortable. But I don’t think a hollow form cares too much… :)
Finished up the walnut hollow form today. It measures 8-3/4” tall x 7-1/2” wide and the base is 2-5/8” per the chart showing hollow form dimensions, base 1/3 the diameter. However it looks fatter in the photo but not in person. I guess it’s true the camera adds 10 pounds😁.
Also turned a few green walnut bowls.
Hi David. Is the walnut hollow form once-turned or twice turned? I turn mine to 3 /4 inch, dry and then turn Thanks.
Working on a December hollow form. Inside is done, so it's on a home made mandrel. Final pass and sand left.
So you are hollowing first? I have always turned outside to finish and then hollow. How is this working for you?
This one is once turned. I haven’t tried twice turning HF’s yet but plan to, especially side grain. The end grain doesn’t seem to move as much as the side grain.
To get an idea how much wood will warp when drying relative to the orientation and where the blank is cut from the tree, look up the species in a chart, or better, in the online Wood Database. For example, look at Black Cherry:
Radial: 3.7%, Tangential: 7.1% Volumetric: 11.5%, T/R Ratio: 1.9
The volumetric shrinkage is important, but tangential and radial shrinkages can make a big difference for predicting face grain turning warping. The tangential shrinkage often about twice that of the radial shrinkage. That causes warp as face grain (flat sawn) turnings dry. One number, the T/R Ratio, puts both of these together. The higher the T/R ratio, the more warpage.
BTW, tangential is tangent to the rings, looking at the end grain of a cross-cut log section. Radial is across the radius of the log, or to minimize juvenile wood effects, from the pith out towards the bark.
For comparison look at the volumetric shrinkage and T/R ratios of Black Mesquite and Red Oak
Radial: 2.6%, Tangential: 3.5%, Volumetric: 8.5%, T/R Ratio: 1.3
Radial: 4%, Tangential: 8.6% Volumetric: 13.7%, T/R Ratio: 2.2
So a face (side) grain blank turning might warp far more than an end grain turning. (All this is the reason that quarter-sawn boards are more stable that flat-sawn boards when working with flat wood.)
This is just an average for samples tested - the actual T/R ratio varies with the specific tree, where the blank is cut from the tree, and the proximity to the pith on one side, or worse, reaction wood. Shrinkage along the grain, the longitudinal shrinkage, is usually so small it can be ignored.
If interested, this Wood Database article might be useful:
Note from this article the seasonal stability is not necessarily related to the wet-to-dry shrinkage.
The T/R ratio is the reason lidded boxes are often made from end grain blanks so the lid is less likely to stick. My solution to things with lids, such as Beads of Courage boxes, where it is sometimes impractical to avoid turning side grain, is to make tapers on both lid and vessel.
There is far more to the story. The best book I’ve found about wood, how it dries, how it shrinks and far more is Understanding Wood by R. Bruce Hoadley. Unlike some practically unreadable technical writings, Hoadley is both a craftsman and a wood technologist and explains things on our level! I keep an extra copy of the book on hand to lend to those who show an interest.
Sorry for the “blog”; hoping this might be useful to some.
I turn the outside first then drill out the middle with a 1/2 inch bit. Hollow out the inside while still attached. Cut off and turn the part that was still hooked by the chuck and reverse it on the mandrel for final smooth and sand. Then finish. Hope I said that right.
Scored another batch of maple squares today!
Chunk of apple. Attempting hollow form number 2 for today.
Yikes what huge calipers! Somehow I ended up with calipers in 4 or 5 sizes. My favorite for small things (small vessels, ornaments and such) are these made from brass. Maybe I'll make some larger ones. Dual mode.
