Finished turning the maple tonight and put a coat of DO on it to try and slow the drying since it was a very wet piece, measures 9-3/4 x 8. May carve some on it once my micro gets here as of now it’s taking a tour of the US thanks to USPS putting it on the wrong truck! It was 3 hours away and it looks like it will take two weeks to get to me!
Told the wife I would do one of these for a while and it came off lathe today. On the finishing table now. Top piece is Red Top, upright is Indian Rosewood, and bottom is walnut.
Very nice! Good form and beautiful color and figure. I’d almost be afraid to carve on it, wondering if carving might distract the eye from the natural beauty.
My general feeling is if the wood is plain, add detail (turned, carved, textured).
I’m with John. Just to beautiful of a piece of timber to carve. Plenty of bland stuff out there.
A mulberry bowl about 8" with lots of cracks. The "vase" is ash with India ink. The ink got a little thin in spots so I'll have to redo it. I'm not sure yet on finish. I might go with shellac.
View attachment 75449View attachment 75450
I ended up putting 3 coats of the India ink on the carved hollow form I did. I used 0000 steel wool to blend the ink after it was dry and before adding another coat, really helped the look.
A piece of redwood burl that my daughter and I turned into a collaborative project. Started out as a real quick turned shallow bowl. It had a a very uneven top side that I suggested we just turn flat. My daughter thought it would be worth a try to make it a live edge bowl. We decided to give it a try despite the fact that the wood had some real soft spots and cracks. We got it turned down to this point and now starting to fill the cracks and crannies with CA. I didn’t think we would get this far before it flew apart, however, my daughter had confidence. We will probably wrap it with Saran Wrap and some duct tape after the CA dries to help hold it together before we do the final inside turnings.
This seemed like a good idea at the time. I decided to make a tripus, a hollow form suspended by three irregular legs defined by the outline of a maple burl about 16" in diameter and 8" deep. I got the primary shape defined, cut out the legs oversized and shaped most of the hollow form bottom between centers, leaving a 6" tenon on a tapered stem. Reversed and hollowed it out, taking the final scraping cut inside the bottom at 550 rpm when one of the legs flew off, punching a hole in the 1/4" melamine coated particleboard backdrop. Drat! If I had left the shell thicker, thinned the legs out more, spun it at a lower speed, worked faster... there's always next time. At least I wasn't in the line of fire.
edit: After a little more thought I realize how vulnerable the legs were to centrifugal force once I had jigsawed out the arcs of material between them. I did this to lighten the piece and bring it into better balance (so I could increase the rpms above 300) but mostly to allow for using the video camera to guide the hollowing tool. Next time I will thin the legs down more and cut holes between the legs, leaving the bottom rim intact - and moderate the speed.. I was surprised that the failure happened where it did at the top of the smallest diameter leg in seemingly strong material, but the 1/4" thick shell did have a void at one edge of the break and the relatively thick and heavy legs trying to fly out at 25+ mph overcame the shell's strength.
I don't like losing the material and work that went into the piece but I learned something useful and didn't get hurt. The hole in the backdrop illustrates the wisdom of wearing face and head protection and staying out of the way as much as possible.
Gearshift knob for a Tr6.
“The Triumph TR6 (1968-1976) is a highly regarded British sports car known for its distinctive styling and performance. It was a popular and successful model, with over 94,000 units produced during its eight-year run. The TR6 is powered by a 2.5-liter straight-6 engine and is known for its blend of power and drivability”
I don't normally post my work to this thread or the forum member's gallery, but my latest batch of about a dozen pieces has just gone to the gallery and they have now added those to their website...
https://www.theateliercrafers.com.au/search?page=1&q=neil+Strong
The pieces get removed from the website soon after they get sold and the listing will dwindle away until I need to take the next batch of pieces to the gallery. I'm fortunate in that the countless hundreds of pieces that I've sent to galleries over many years have all sold, eventually, which allows me to keep turning and learning.
So, this is by way of a show and tell of what was recently on my lathe... no two pieces are the same because every piece of wood is different, as the ticket that goes with each piece says:
Beautiful pieces of wood that guide me
in what form they might take in their new life
beyond the living tree
Looks good and I see selling. What is old Red Gum? Why not just Red Gum?
Red Gum darkens with age after being cut, but it takes a very long time for that to happen, like a century or more. The older the Red Gum gets the darker it becomes. My main source is large old recycled stockyard corner fencepost that have stood out in the weather for all that time. You don't get too many of those now and sadly you won't in the future with newer fencing methods.
Here is the difference. The piece on the left below has had no time for its wood to darken since coming down. The one on the right was from a fencepost that would have been 100 to 120yrs old and I've had it in my stash for a further 50yrs. With that piece I left the weathered surface of the fencepost on the rim of the bowl for the connoisseur who will appreciate that... :)
IMG_5109.JPG Old Redgum - bowl with original fence post surface edge12cm.JPG
The lighter Red Gum sells well, but I can put a higher price on the aged wood.
