Some mango that was cut down recently. A facebook member on the florida woodworking account put out the location on a massive mango tree that had been cut down and was sitting on the side of the road. Of course they cut it in all the worst ways possible.
I found some great pieces though!
This one is currently sitting wrapped up on my lathe. I'm attempting to decide what direction to go! The bark has stayed in nicely so I'm tempted to include it.
About 13in long x 7in wide right now
I decided to put splines across the bark inclusion on this butternut crotch bowl. the last time I used splines I just cut a grove across the ark, but I didn't like the look of that method. The groove on this one was plunged all the way through with a 1/2" up cut solid carbide bit. The splines were made from 1/2" X 1 -1/2" butternut with one end rounded over with a 1/2" half round bit, marked for the other end, cut off a little long and cut the other end.
View attachment 85685View attachment 85686
Walnut, 8 x 4.25
Candy dish with embellishment done with an ebay knurler.
For $12 it'll work (on walnut anyway)
Hi, really interested in what you've achieved using your eBay knurler. The chequered pattern is really good. I've tried one before but with limited success, in fact it was a complete failure to be honest but I may have bought the wrong type. Have you still got the details please.
IMG_4838.jpegwell worked on this today, it’s off the lathe now! Our Long Island woodturners association is doing a wig stands for cancer donation to local cancer treatment centers
We were able to uptain a donation of popular wood from local wood suppler
Here’s a look of my first try! Still needs to be stained and finish applied.thinking maybe using some oxolic acid to remove the green so stain will look better?!
I think it is red oak, judging by the red in it. But, I’m no expert.
Wood ID is a bit of a hobby with me.
If you suspect your wood is oak, shave across the end grain of a small scrap with an single-edge razor blade or extremely sharp knife. You don't need to shave a very wide area - just enough to reveal a few rings. All will be revealed.
This is what you will see with red vs white oak under low power magnification.
These are easily visible with a simple 10x hand lens. I use a low-power stereo microscope in my shop which is easier.
Both red and white oak have fairly wide rays (vertical lines in these photos), distinctive large early wood pores, (at the lower junction of each ring) and what I call distinctive "tornadoes" of latewood pores. Latewood pores are at the top of the visible ring, are generally small in size, and often have distinctive configurations.
Note that large earlywood pores of white oak are filled with what might look like tiny crystals call tyloses; red oak pores are empty. The clogged white oak pores are what makes them good for outdoor furniture and whiskey barrels.
However, Red oak generally has a uniform slightly "redish" color unlike white oak. It doesn't oftan have the red streaks shown in your piece. I see these more in other species, for example Canary wood.
Useful reading is the Wood Database article on identifying wood. The Wood Database also has end grain photos of every species. See section 7.
And if you care, note the instructions at the bottom of the article on how to get professional wood ID.
Or better, the book "Identifying Wood" by R. Bruce Hoadley.
Or do what many do, just make up a species name and write it on the bottom. That's how I got started in wood ID - someone passed around a bowl labeled "Cherry" on the bottom. One quick look at an end grain section did not show the diffuse porosity distinctive in all cherry. To avoid loss of respect by those who know, maybe don't write a species name on the bottom! If someone asks, just say "don't know, what do you think!"
And, @Joel Daniels, another very useful web site is the oddly named HobbithouseInc. Here's there article on Red Oak.
Down the page you'll see a huge number of photos of the various red oak boards. You can check if your piece is consistent with any.
Just for fun, here's there page on Canary wood. Keep in mind again, that with ANY species there will always be a huge variation in what the face grain of a board varies.
Note there is far more verified info on domestic US species than many "exotics".
JKJ, certified, card-carrying, amateur wood ID wannabe.
@John K Jordan thanks for info. Here’s a closeup pic of the end grain. I think it looks more like red oak but I like your last comment - it’s just oak if anyone asks!
Hard to tell if there are tyloses in the large earlywood pores without shaving the end grain with a razor blade. All you need is a scrap piece about 1/2" wide, maybe 3/4" long, and deep enough to hold onto. All becomes clear when the sample is prepared cleanly. Some made the mistake of sanding first which obscures things.
I buy single-edged razor blades in packages of 100 for this. An extremely sharp knife may work, or a scalpel (but a scalpel blade is easier to break. Blood spilled on the wood sample doesn't help.
Thank you for posting that link, lots of excellent info on that site, 😎🤙🏻
This was a smallish (11" or so) persimmon that had to come down. I cut it down 18 months ago and set it out to spalt. 6" bowl. It's still very green so will look a bit different when it dries.
View attachment 85925View attachment 85927
Kent,
What did you do to get the spalt going?
I have a bunch of kinda plain jacaranda that i know spalts well, but it also rots well, spalting it would make for some nice turnings though.
Kent,
Here in Tennessee all I have to do is let it sit on the ground. I stood some short log sections on end, and the rest I left on their side. Sugarberry/hackberry spalts here in just a few months. Maple, too. The persimmon seemed to take longer.
A gentleman on another forum described his spalting "farm". Cut maybe 3' length of logs,set one end flat on the dirt and leaves (fungii are everywhere!) covered the other end to protect from sun and drying, and waited.
Every few months in warm weather he'd take a chance and cut some off the end. Said it was more a guess than anything. If the very end showed strong spalting or signs of beginning rot he would cut higher on the log to see what he had. Sometimes got lucky.
I have just piled logs in the swale between our and our neighbor's property and let the rain wash through while they are on the ground with windblown leaves piled around... check every month or so - sometimes lucky, sometimes rot and they go to the compo0sting pile out back to grow mushrooms
Are there different types of persimmon? Chunks I have were very white with a small black center. Course I haven't gotten around to doing anything with them yet so maybe they look like that inside now.
I don't think there are types of persimmon. These logs have been sitting in the elements for 18 months. Most of the color variation you are seeing is probably the spalting. The very small black heartwood is often not even present.
Persimmon is in the ebony family, and used to be used for golf driver heads before they got the fancy metal ones. As for spalting, check out Seri Robinson, aka Dr. Spalt. Mostly it takes about 6 months, and some moisture in the wood. Not sure if it is possible for dried wood to be wet up again to the point where it can spalt or not. Much more than 6 months and it gets too soft since spalting is the first step in rotting. Some woods spalt more easily than others.
